My latest activities(LOTS OF PICS) http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=5299 |
Page 1 of 2 |
Author: | Serge Poirier [ Sat Feb 25, 2006 12:23 am ] |
Post subject: | |
My # 2and # 3 are officially started, i joined the plates last week with HHG and it went rather well except for me being messy ![]() useruploads/SergePoirier/2006-02-25_080448_DCP_0906.JPG[/IMG] I also made some templates out of a piece of plexiglass that a friend gave me I also finished my side bender, inspired by Jc Jones, Bruce Dickey and Lance's bender so i have a mix of bending ideas. It's still a bender, not a blender ok! Last night i thicknessed my tops in preparation for my rosettes and my drum sander was up to the task and made me really proud, 1/4 turn on the lever and just a fine hair was taken off at a time! ![]() ![]() My sander in action with the dust port! Sorry for the lenghty post, i was just happy with the way it all went last night that i wanted to share those good moments with you all. We even had an 4 RS earthquake while i was at it but never felt a thing, i was too concentrated on thicknessing while the elders were running for cover! Serge |
Author: | Josh H [ Sat Feb 25, 2006 12:48 am ] |
Post subject: | |
Serge Looks like you are well on your way! It looks from here like that is a pretty tight cutaway you have going on. Make sure you thin the cutaway portion more than the rest of the side so that it will bend easily. I think the rosewood will probably be able to make that bend, but I wonder about some other woods. I have no experience with machine bending so I can't really comment on how it might work. Let us know how it goes eh!?! Josh |
Author: | Bruce Dickey [ Sat Feb 25, 2006 12:52 am ] |
Post subject: | |
Serge, You've been quite industrious. That's some fine looking wood pieces you have joined up for those guitars. Even earthquakes can't make a committed luthier leave the joy of guitarmaking. Nothing like the feeling of progress in the shop. Best wishes for may more days and nights like that for you! |
Author: | Colby Horton [ Sat Feb 25, 2006 12:57 am ] |
Post subject: | |
Lookin' Good!! Got any more info on that homemade drum sander?? |
Author: | Serge Poirier [ Sat Feb 25, 2006 1:09 am ] |
Post subject: | |
Josh, Thanks for that great advice, i must admit i did not think of that but i will remember it when thicknessing the sides ![]() I'll let u know for sure! Hesh, thanks, yes it's a Dread(sorry for swearing ![]() ![]() ![]() ![]() Thanks Bruce, My tops are Lutz S from Shane and they are just so beautiful that i could stare at them all day and all night but hey, i'm a junkie hooaaahhh! ![]() |
Author: | Anthony Z [ Sat Feb 25, 2006 1:12 am ] |
Post subject: | |
Hey Serge-- man you've been busy! Building all those jigs and the thickness sander sure adds time to your build. Good stuff! |
Author: | Serge Poirier [ Sat Feb 25, 2006 1:24 am ] |
Post subject: | |
Hi Colby, the iron table was given by my brother Martin, the motor is 1/2 hp, bought from an old pal for 50 bucks and runs at 1725 which is plenty enuff for this. At first, i did like most do ie a drum made with glued discs of 3/4" plywood but it was too heavy for 1/2" shaft so i thought of using 3" ABS PIPE which is already trued and inserted 2 small discs of ply at each end of the ABS drum and drilled 2 center holes 1/2" for the shaft to go through the drum and get to the 1/2" pillow block bearings. The motor is suspended on a springed table for pression on the belt and the plate on which i feed my wood is hinged on one corner of the sander. The mechanism for lifting or lowering the feed table is very simple, it's just a 1/2" threaded rod going through 2 bars with welded nuts( welded by my pal Jacques) and i added a metal plate under the table so the threaded rod did not damage it. the drum allows me to 18" to sand, it's good enuff for me now but would go for 24" min. if i were to do it again! Thanks Anthony! |
Author: | Rod True [ Sat Feb 25, 2006 1:34 am ] |
Post subject: | |
Serge my friend.... things are looking realy good. Great job, I'm proud of ya. Along with thinning the side in the cutaway, make sure you have good heat there and GOOOOO SLOOOOOWWWWW when bending it, just hand pressure (wear a good heat resistant glove) and realy let the wood form round that bend, I'm assuming you will be using your heat blanket and steel slats (can't remember if you have the SS or the spring steel), those slats will help support the wood on the outside of the bend. #2 and # 3 well on there way. Great job. ![]() ![]() ![]() ![]() |
Author: | Serge Poirier [ Sat Feb 25, 2006 1:42 am ] |
Post subject: | |
Thanks Rod, i do not have the stainles steel slats, i do have 2 slats of some galvanized stuff i used for my first build but i might check out the options for that kind of bend which is pretty dramatic! ![]() ![]() |
Author: | LanceK [ Sat Feb 25, 2006 2:17 am ] |
Post subject: | |
Lookin good Serge! That is a very ambious curve you got going there! I would probably thin that down to about .060 where the apex of the curve is, and even then, luck MUST be on your side to get that done. ![]() When I designed my cutaway models I used the cap from a can of spray paint to find the curve. Im not saying that yours wont work, because it very will may. ![]() |
Author: | old man [ Sat Feb 25, 2006 3:00 am ] |
Post subject: | |
Serge, you've come a long way in a short time. Your workmanship is looking good. Can't wait to see your latest creation. I've started #2 and #3 also, but I'm doing the necks first. Almost have them machined. Keep us posted. (as if you wouldn't ![]() ![]() ![]() ![]() Ron |
Author: | Bobc [ Sat Feb 25, 2006 3:17 am ] |
Post subject: | |
And I thought you spent all your time posting. ![]() |
Author: | peterm [ Sat Feb 25, 2006 3:38 am ] |
Post subject: | |
Congratulations! ![]() looks like you have spent your fair share of time with your....hmmm... sould I say "hobby"? ![]() |
Author: | Serge Poirier [ Sat Feb 25, 2006 4:30 am ] |
Post subject: | |
Thanks folks for the encouragement! To avoid any confusion, the drum sander was built last summer and took me a bout a month OR 2 to build on evenings and week-ends so you know that i'm not that quick of a builder yet. When everything runs smooth tho, i must admit i can be prolific there as well ![]() ![]() ![]() Thanks for the tip Lance, i'm also considering adding a hot pipe to my arsenal of jigs and tools to achieve this bending.I might also order some practice wood for bending that kind of cutaway and see how it goes. Kind of nice to be working with real wood instead of ply! ![]() |
Author: | Cocephus [ Sat Feb 25, 2006 5:22 am ] |
Post subject: | |
Way to go, Serge! Your bender is set up alot like mine, just don`t have the cutaway, though. Glad to see you`re making progress ![]() |
Author: | Mattia Valente [ Sat Feb 25, 2006 7:21 am ] |
Post subject: | |
Looking sweet! Getting a lot done, too, if I'm seeing things correctly. Rockin'! |
Author: | Joe Beaver [ Sat Feb 25, 2006 8:43 am ] |
Post subject: | |
Serge, Nice work all around. The template has a pretty aggresive cut away profile. Let us know how the bending goes. Or is it Blending? |
Author: | Kim [ Sat Feb 25, 2006 9:13 am ] |
Post subject: | |
Great work Serge, coming along nicely. Your sander looks very stable and seems to have done a great job of thicknessing for you congratulations. ![]() ![]() ![]() Cheers Kim |
Author: | Shane Neifer [ Sat Feb 25, 2006 9:16 am ] |
Post subject: | |
Serge, CHARGE!!!!! Man you ARE at it! I think everything looks tremendous also. But please do try some practice wood on that curve before you bend a matched set. I think it is a pretty tight bend but when you are successful at it it will be your trade mark! Shane |
Author: | Serge Poirier [ Sat Feb 25, 2006 10:52 am ] |
Post subject: | |
Thanks again ya great folks, i'll try not to let it go to my head though and sure am proud to be able to at least share this much. This morning, i attempted to cut slices of purple heart for my rosettes with the bandsaw but it didn't go that smoothly, the blade would fall off the wheels along with the rubber things that are gettin' tired around them wheels ![]() ![]() ![]() Serge |
Author: | Kevin Gallagher [ Sat Feb 25, 2006 11:43 am ] |
Post subject: | |
Serge, Looks good! You're obviously an ambitious guy. Thet cutaway is going to be a tough bend. Let us know how different woods behave on it for you. Regards, Kevin Gallagher/Omega Guitars |
Author: | Rod True [ Sat Feb 25, 2006 4:34 pm ] |
Post subject: | |
Serge, how wide is the purple heart? you could always use a thin kerf sawblade and cut it on the table saw, start on one side than flip to cut the other, than run it through your sander, I know you will loose a bit more this way, but if the bandsaw isn't cutting it (pun intended ![]() |
Author: | Rod True [ Sat Feb 25, 2006 4:40 pm ] |
Post subject: | |
Hey Serge, I was taking a second look at your pics and noticed this ![]() That's not a gap is it? I'm hopeing that it's just a thick pencil line and not a gap or the plates separating. Please check it out, I would hate for you to route your rosette channel than have to pull the plates apart and re-shoot and join them. |
Author: | Serge Poirier [ Sat Feb 25, 2006 4:51 pm ] |
Post subject: | |
Thanks kevin, after discussing with another member here, i changed my mind regarding that severe cutaway, i'll be going back to the drawing board for a less severe one, it'll only be a short delay but really worth the extra time to save my EIR from crackin'open! Cool advice my friend Rod, my purple heart is 6" wide by maybe 1/2", the thin kerf blade sent by Shane should help get very thin rosette veneers. Question, could you tell me what pun means ? I've been meaning to ask for a long time but was too shy. Is it that you're just rubbin' my Bear back ?TIA Serge |
